Morimoto HID bulbs, MH1 v5 sheilds, LED Halos, P5 Headlight graveyard
Morimoto HID bulbs
The leftovers from my retrofit project. Paypal or cash pickup. PM me to get my paypal email and confirm availability before paying.
Morimoto 3Five HID bulbs - $30 shipped
- H1 bulb type
- 5000k
- Used for maybe 6 months, an hour per night
Morimoto Mini-H1 v5 projector shields - SOLD
- With foreground limiter
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6271_zps63487651.jpg
OCI Butyl Rubber Glue - SOLD
- Used maybe 1.5 feet for 2 headlights - TONS left
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6272_zpsc4655b19.jpg
Morimoto XB-LED Angel Eyes - SOLD
- Amber color
- Sized for Mini Graphite shrouds (for sale below)
- Used for maybe 2 weeks
- Wiring was cut between voltage regulator and LED, but can easily be soldered back together with no issues
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6274_zps31d1aae8.jpg
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6273_zps0dc6f0ef.jpg
Mini Graphite Shrouds - SOLD
- Works with Morimoto Mini H1 projectors
- Had some double-sided tape residue on the inside, but some googone should be able to take care of that
- Lens Diameter: 2.5
- Mounts with: Centric rings (not included)
- Height: 88mm (3.52 inches) | Width: 100mm (4.00 inches) | Depth: 57mm (2.30 inches)
- Internal Halo: 80mm (for sale above)
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6277_zps511755f5.jpg
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6278_zpse48fc176.jpg
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6279_zps903997cb.jpg
Headlight Graveyard
I have a bunch of Protege5 headlight parts for sale. Some I will split, some I will not.
Pair of OEM Protege5 Lenses with blacked out shrouds - SOLD
- Blacked out by me 2-3 years ago
- Will NOT split up
- Lenses could be polished clear, with a lot of elbow grease
- Some light cracking at the edge of the driver's side
- Perfect if you want minimal downtime to do the shroud blackout
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6280_zps9efc902e.jpg
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6281_zps0e5408de.jpg
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6282_zps37ad23a7.jpg
1 Depo and 1 OEM Protege5 lenses with stock chrome shrouds - SOLD
- Black out the shrouds yourself
- Will NOT split up
- 1 lens has the edge broken off
- Other lens has hairline cracks on it
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6288_zps6e5c8240.jpg
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6289_zpsfdafe06b.jpg
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6290_zpsc3dd8a13.jpg
Driver's side headlight housings *- Both SOLD
- 1 DEPO
- 1 OEM
- Good condition - all adjustment screws are tight
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6291_zpsdf9cd789.jpg
2 Passenger side headlights - GONE/SOLD
- Both OEM
- One has loose adjustment screws (headlight may or may not be able to be adjusted up/down) - Sold
- Other has severely broken reflector bowls, and loose adjustment screws (this is what happens when your MH1 projector retention nut freezes and you need the rubber piece and housing centering washer out of it LOL) - Thrown away
http://i351.photobucket.com/albums/...3-f3f5-4cd9-b54a-a3ad8662468b_zpscd9f4910.jpg
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6296_zps7e7ffae6.jpg
http://i351.photobucket.com/albums/...adlight Graveyard FS/IMG_6295_zpscf70dce8.jpg
Come thursday/payday. I might buy those chrome shrouds. That way I could start my retrofit and be able to paint without being disassembled for a whole day
Say you were going to be doing a retrofit. The loose adjustment screws on the pass. side wouldn't matter, or would they?
Exactly why they are for sale! Let me know when you are ready :)
Depends on the retrofit. You would need to do something to tighten them or the entire reflector (which the projector is mounted to) would bounce around.
Im Thinkin I Might Buy the Black shrouds depending on how soon i can get y car out of the shop
but on a serious note, how easy is it to do that?, i hear its no too bad
Its not too bad, just time consuming. If you can't have your car down for very long, having the extra shrouds makes the process much quicker, since you don't have to wait for paint to put your car back together.
