Hi there guys,
I was wondering if anyone could tell me where is the best place to hook up the vacuum line for the wastegate and the BOV. Also, can someone tell me if this fitting works, http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-OIL-010&Category_Code=, and could be directly threaded to the back of the block for the oil feed line and can the oil pressure sensor can be hooked up? Next question is, I was told that the fuel pump and injectors needed to be changed if I was going to boost my P5, is this true if I am going to run factory MSP setup?
I was also told that the head and pistons on the MSP are different from regular 2.0 the P5 comes with. I am getting a lot of mix signals from different ppl, can someone please point me out toward the right direction. All of my turbo parts are OEM except the manifold and the FMIC and bov. I have pdf the how to turbocharge your P5 thread for me to refer to but, there is not how to on vacuum lines. I would really appreciate all of the assistance.
