Hi
Was just wanted to get peoples opinions on raising the front of my car. It currently sits 1.5cms lower than the rear when measured from the same point on the wheel, and since the ride is fairly poo over bumpy roads i wanted to know if raising the front another 1.5cms will allow for a noticeable difference in ride quality since it will allow more shock travel?
The car does get unsettled over bumps in straight lines and when braking causes abs to trigger very easily. I have not noticed how the car reacts during bumps in corners and seems okay from memory. Is there a good way to test this?
I know this is as good as anyone's guess but will it change the camber a lot? It currently sits on 2.2 and 2.4 both sides. I had elongated holes on the shock to hub mounts, but they are now welded shut after coming loose at the track.
The car is currently corner weighted at the current height and know it will loose it but i feel i need to refine the settings more to be happier with how the car handles and reacts over bumps.
I am currently looking at possibly upgrading to swift springs also but don't want to spend the extra money yet since they are fairly pricey.
Feel free to chime in and give advice.
Cheers
Jo
Cheers
Jo
