more power!!!!
jdm4life
i have a 2003 mazdaspeed protege that is basically stock it has a fmic with hard pipeing,injen intake,ngk cold plugs,and ngk wires....what could i do to the car to get big power results and make it quicker? thanks....also what tune do you use to tune the mazdaspeed protege?
first, read --> http://www.mazdas247.com/forum/showthread.php?t=123677826
Exhaust is the biggest thing, so a free flowing exhaust should be next. For tuning, most would probably tell you about the SSAFC. It works great unless you are going for big numbers, standalone is the only option. Speaking of that, your goals depend on what you mean by "big power results". Do you want a quick bolt on car or are you going all out and rebuilding with forged internals since the stock internals are like playing russian roullette.
You can look into getting stiffer motor mounts since the stock mounts suck, possibly a welded LSD or better, boost gauge and wideband to monitor your boost and air/fuel mixture, intake and exhaust manifolds, boost controller at no more than 9-10 psi with tuning. There is so much you can do with these cars from suspension to motor work, hell even new shifter bushings can change the way the car feels. Im pretty sure someone will chime in with more info but just browse through the MSP performance forum. You will find lots of info on what you are looking for.
exhaust is the biggest thing, so a free flowing exhaust should be next. For tuning, most would probably tell you about the ssafc. It works great unless you are going for big numbers, standalone is the only option. Speaking of that, your goals depend on what you mean by "big power results". Do you want a quick bolt on car or are you going all out and rebuilding with forged internals since the stock internals are like playing russian roullette.
You can look into getting stiffer motor mounts since the stock mounts suck, possibly a welded lsd or better, boost gauge and wideband to monitor your boost and air/fuel mixture, intake and exhaust manifolds, boost controller at no more than 9-10 psi with tuning. There is so much you can do with these cars from suspension to motor work, hell even new shifter bushings can change the way the car feels. Im pretty sure someone will chime in with more info but just browse through the msp performance forum. You will find lots of info on what you are looking for.
+1
vtcs removal/ port and polish the intake manifold is a good one too. and its practically free if you do it yourself!
