modified and track ready ms3
Modified internals: head bolts, ACT clutch - flywheel - pressure plate, hotter denso plugs, Quaife limited slip differential, new timing chain....
CPE High pressure fuel pump....
CPE Engine mounts (3)...
CPE Intercooler..
AEM large front mount intercooler....
COBB Blow off valve...
Braille light weight battery...
Computer flash done in England - allows for 24lbs. of boost.
(FRONT)KW coilover Variant 2, compression, rebound and ride height adjustments...
(REAR) KW shocks and springs, compression, rebound and ride height adjustments...
Mazda's Tri-Point racing built adjustable lower A arm and support link allows for at least 6 degrees camber and 6 degrees caster...
HKS down pipe and turbo X exhaust....
Slotted front rotors, Carbotech race pads front and rear (most significant mode)....
Enkei 9"x17" light weight race wheels...
Hotchkis sway bars, front and rear, 3 way adjustable at the rear....
AutoMeter boost, oil temp and oil pressure gauges....
Oil filter sandwich plate....
AutoPower roll and seat belt bar.....
Not installed parts:
2 Sparco racing seats (sliding)...
Schroth racing belts for both sides...
Power steering deleat kit...
Methanol injection kit....
List Date: 3/16/2015
For more info, click here to view the original listing: modified and track ready ms3
On Sale For: $15,000.00 (Local Pickup Only)
********************/analytics/ga/mazdas247
CPE Intercooler..
