Mk1 ECU Pinout
bloodline
Hi all,
I know some here have access to information that us mortals are not privy to.
I have a wiring diagram for my pre '93 MX5/Eunos/Miata (however you wish to call it), but all it shows is the connection paths of the wired in the wiring loom, not the actual name/function and nominal voltages of the lines.
I want to build a USB interface board to start playing with my MX5's engine, using a USBMicro U421 interface board, which I have used in a previous project.
From what I can see from my diagrams, most of the engine sensors appear to be analogue, so most of the work would need to be building a set of Analogue to Digital convertors.
Any help, many thanks!
Hi all,
To answer my own question:
http://www.miata.net/garage/ECU_Pin-Out.png
Might I suggest looking into MegaSquirt. You'll end up with the same result for about $200 and a lot less overhead.
Thanks for the update with the link! That can be quite handy to have around.
