Mechanical or electrical Boost guage?
speed3 britz
07 Mazdaspeed3, 93 B2600i 4x4
Ok so im looking to get some Prosport guages for my ms3. Lookin to get the cpe dash pod with boost, oil temp, and oil press. Whats the difference in the electrical and mechanical boost? Ima bit of a noob to this so i dont know. Is one better than the other, or easier to hook up? Let me know what u guys have
No offense, but ARE YOU SERIOUS???
Electrical vs Mechanical is self explainatory.
ok well i didnt mean it like that, yes i understand the difference between "mech" and "electrical" (ones controlled electronically, the other almost directly, hence mechanically).... but i meant whats the differences, as in advantages of one over the other. ive never hooked up extra guages in any of my cars before and thats why i ask.
I prefer mechanical. I like the direct vacuum line running to the back of the gauge. You don't have to worry about sensor failure or variations in sensor sensitivity or accuracy. Even very inexpensive mechanical gauges tend to be very accurate and tend to last longer than you will ever own your car.
I like the VDO mechanical. That company provides OEM gauges for a lot of auto manufacturers, especially in Europe. it has an excellent reputation for accuracy and reliability. I just like the vacuum or boost directly moving the gauge rather than relying on electronics to interpret from a sensor and then send a secondary signal to the gauge. Too many steps and too many ways to inject inaccuracies.
If you do decide to go electronic then the only real benefit, IMHO, is if you use the sender (map sensor) already present in the car and monitor the boost data through the OBDII port. That's what you would get with a Dash Hawk or Cobb's AP. If you are tuning to a specific target and want your gauge to read the same thing the ECU is seeing (questionable validity IMHO, because I want to know absolute boost), then you can adjust ECU mapping to what the OBDII port is reading.
Thank you sir, you answerd my question, i think i will go with mechanical because of this (2thumbs)
