Hi everyone,
I have a 1st gen 2009 Mazda 3 2.0L Automatic with 120K miles, for the past 3 months I've had this annoying problem; when I slow down (say for a speed ramp or s/thing) from any speed to around 15mph, the car shifts down as it should to 2nd gear & as soon as I want to accelerate again & let go of the brake & push down on the gas pedal there's a 2-3 second lag with the revs sticking for 1-2 seconds & then the car accelerates. No Check Engine Light or any other problems seen. Gearbox shifts normally through gears.
It's taken me ages to go through the following but no joy so far!!!!!!!
checked;
coils & plugs (NGK Laser Iridium)
air cleaner
cleaned MAF,
purge solenoid valve
MAP
fuel filter
EGR
No apparent vacuum leaks
cleaned the throttle body
reset ECU & let it run for 20mins etc.
Any help would be greatly appreciated.
checked;
air cleaner
cleaned MAF,
MAP
fuel filter
EGR
