Ethanol information for Mazda vehicles
What is Ethanol?
Ethanol is a colourless liquid (alcohol) which is produced by fermentation of sugars and carbohydrate polymers and is generally manufactured from grain or sugar. Blending of ethanol in petrol has been suggested as a means of reducing greenhouse gas emissions and alleviating adverse economic conditions in the Australian sugar industry.
The Australian Federal Government is currently legislating that ethanol can be added to petrol in blends of up to a maximum of 10%. This is called E10. Legislation states that this must be labelled on the petrol station pumps which dispense E10, so that the consumer will have a choice whether or not to purchase ethanol blended fuels.
Mazda Corporation of Japan has supplied a list of vehicles which can operate on ethanol blends of up to 10% (E10). These vehicles are listed in the table below. Mazda Corporation has advised that vehicles which are not listed in the table ARE NOT SUITABLE for use with ethanol blended fuels.
Issues which can arise as a result of ethanol being used in non-suitable vehicles
* There is an increased possibility for the metal fuel tanks and lines to corrode or rust.
* There is an increased possibility for plastic fuel tanks to swell and break down.
* There is a possibility for plastic and rubber fuel lines to deteriorate.
* There is a possibility for fuel injector o-rings to break down.
* Carburettor floats and seals are susceptible to deterioration.
* Certain engine components may not be compatible.
* Engine management mapping parameters may not be entirely compatible with E10, thereby creating idle and driveability concerns, starting concerns and hot weather performance issues.
Points to note
* Ethanol is an oxygenated fuel. E10 (which is oxygenated gasoline) may reduce fuel economy by an average of 2 3% because oxygenates contain less energy than non-oxygenated petrol. As such, there may be fewer kilometres per tank of fuel when using E10.
* Ethanol has a high affinity for water. Therefore, ingress of water could result in ethanol blends of petrol to break down into separate water/ethanol and petrol layers. This could create driveability concerns as there is the possibility of water/ethanol slugs reaching the engine.
* In some older vehicles, deposits in fuel systems can be loosened by E10 which may cause fuel filters to become blocked.
* Coarse ethanol, which is of poor quality (like ordinary fuels of poor quality), may cause poor idle, derivability concerns and starting issues, even if the vehicle is suitable to operate on E10.
Model Beginning MP year Engine Name Engine Capacity (L) Comments
Mazda2
DY 2002 ZY 1.5 litre 4 cyl All Mazda2 models
323
BA 1994 BP 1.8 litre 4 cyl Only 1.8 litre in BA series
BJ 1998 FP 1.8 litre 4 cyl Does not include 1.6 litre engine which is not suitable
BJ 2001 FS 2.0 litre 4 cyl Does not include 1.6 litre engine which is not suitable
BK 2003 LF 2.0 litre 4 cyl
BK 2003 L3 2.0 litre 4 cyl
Premacy
CP 2000 FS 2.0 litre 4 cyl Does not include 1.8 litre which is not suitable
Mazda6
GG/GY 2002 L3 2.3 litre 4 cyl All Mazda6 models
800M Millenia
TA10J3
1999 KJ 2.3 litre V6 Miller Cycle Only series 3 and 4 models
TA10J4 1999 KJ 2.3 litre V6 Miller Cycle Only series 3 and 4 models
RX-8
FE 2003 13B-MSP 1.3 litre RE
MPV
LW 1999 GY 2.5 litre V6 All front wheel drive models only
LW 1999 AJ 3.0 litre V6 All front wheel drive models only
Tribute
EP 2001 ZETEC 2.0 litre 4 cyl All Tribute models
(*UO***) 2001 AJ 3.0 litre V6 All Tribute models
E-Series Van
SK 2002 F8 1.8 litre 4 cyl Fuel injected models only
SK 2002 FE 2.0 litre 4 cyl Fuel injected models only
E-Series Cab Chassis
SY 2002 FE 2.0 litre 4 cyl Fuel injected models only
MX-5
1998-2002 BPD 1.8 litre 4 cyl
info taken from mazda australia. thought you could be interested.
What is Ethanol?
Points to note
Mazda2
323
Premacy
Mazda6
800M Millenia
TA10J3
RX-8
MPV
Tribute
E-Series Van
MX-5
