Mazda 6 Spark Plug Wires
zo6om
hello
i have Question ? for mazda 6 Spark Plug Wires
what is different between original Spark Plug Wire for mazda 6 and this item OML Company Spark Plug Wire design for mazda 6
http://jbrlsr.com?aid=5336121789&bi...017QQitemZ270320421537QQrdZ1QQsspagenameZWDVW
OML using OML Premium Wires 8mm 2.3L Mazda 6
what about the size in original mazda 6 spark plug wires ???
becuase i need 2 make service and change spark wires with original new wires kit or better 2 use OML Premium Wires 8mm ????
well obviously you have never seen the plugs or coils on your engine since it has coil on plug setup which means your plug wires are about 4 inches long and are part of the coil. that short or arcing distance you dont need to ever replace them unless they go bad, unless you have an 03 but if thats the case you need to trade in for a speed model or newer, i forgot 04-08 have coil on plug but 03 is wires -wierd
