Mazda 2/Demio Performance charts
iunno if i can really believe that the 2 has a meager 5% drivetrain loss...i think your graph numbers are a little bit more believable as far as Corrected WHP with about 84 whp stock and 87-89whp with your new muffler
stock 2 has about 16% driveline loss on our dyno
which would make her graphs completely believable and the written in numbers very skewed per my original conclusion. 95.5 whp i knew was way too high to be a stock dyno
Did 2 pulls today
Run 1: 81.45 HP, 84.62 Ft-Lbs, 58.4*F
Run 2: 93.77 HP, 97.31 Ft-Lbs, 61.0*F
Nothing changed on the car or dyno between runs; maybe the way the dude staged the car on the drum. Was on a Dynojet.
from the looks of it, you might have had a pull in 3rd gear then a lower or higher gear maybe
It was more than likely a setting such as forced scaling that was input. Nothing to worrie about just a display setting.
