I hope I still can do the oil change at 85 (provided I can live that long) ! By that time most ICEs have already been forced out, and no more oil changes ⋯I changed the oil (Mobil1) and oem filter in my 2022 CX5 NA. I am 85 years old and it is getting more difficult to do this.
Getting older, myself. Old injuries preclude any twisting and torquing around underneath a vehicle. Been that way for the past handful of years, other than spark plugs, air filter, and easily-reached stuff in the engine bay. Heck, even polishing and sealing the paint gets painful. Got to love gettin' older. Just a matter of time.
That right there is exactly what this is all about. I can certainly afford to pay someone else to do the stuff I DIY and suspect that's also true for the majority of DIYers. It simply comes down to the fact that I WANT to do it and get a lot of satisfaction being able to continue doing things myself. I hope to be able to keep at it right up to the time they drop me in the pine box..... As hard as maintenance is for you now, imagine how hard it will be letting someone else do it for you. ....
Hats off to you for still being able to do this. I just don't trust others to do such a simple procedure correctly. Most times, with my experience, the oil level was too much leaving it to my dealer when I had them do it. I guess the dipstick was just an engine ornament. It's kind of like wheel lug nuts, why do they have to be so tight from a garage?I changed the oil (Mobil1) and oem filter in my 2022 CX5 NA. I am 85 years old and it is getting more difficult to do this.
Even worse from my limited experience is the tech forgot to tighten up the drain plug causing the oil leak in addition to the almost guaranteed overfill.Hats off to you for still being able to do this. I just don't trust others to do such a simple procedure correctly. Most times, with my experience, the oil level was too much leaving it to my dealer when I had them do it. I guess the dipstick was just an engine ornament. It's kind of like wheel lug nuts, why do they have to be so tight from a garage?
Or the place that let the tire changer guy do my oil change. I handed the service writer a new (rubber insert type) drain plug washer to give to the oil changer. The oil changer stacked it on top of the existing washer and it leaked. When I complained and wanted it fixed, the service manager balked about wasting new oil when the plug is removed. It got fixed and was the last oil change that place did for me. Reminds me of the term "garage monkey"..Even worse from my limited experience is the tech forgot to tighten up the drain plug causing the oil leak in addition to the almost guaranteed overfill.
That's a great idea. Wouldn't have thought of that.I have seen on this site where a person used a shop vac to draw a vacuum on the crankcase so they could change out a drain plug gasket.
