M3TH 0-60mph with P-Gear GPS Box
CX-5 2017 GT AWD
I have seen a lot of people using Draggy. Got hold of P-Gear several months ago but was not able to use till today. This is my first time to try it. Traction off/ sportsmode/automatic. Slight sub 6 only.
I believe I've read 0-60 in 5.8 seconds - not bad compared to 7 seconds for the non-turbo. If you get lighter wheels, that should lower your time a bit. I saved almost 10lbs per wheel by going with Enkei Racing wheels. (just a bit over 17 lbs vs. 27 lbs each for the factory 18-inch wheels)
