What are the causes of low vacuum pressure on these cars? On cold startup I have about 15 in hg and after warm up about 17.5 in hg. Everything I read says a normal engine should have at least 20 in hg. Does this indicate worn valve seals or piston rings? I've looked over the vacuum lines and do not see any place for there to be a leak, could a very small vacuum leak cause a reading this bad? Is there any way to test the gauge?
