Low Tire Pressure Warning
Lancer Ralliart Sportback
Issue - i am still getting a low press warning after a few miles of driving. I am convinced one of the sensors is not reporting and the computer waits an appropriate amont of time for a signal and then triggers the light.
New tires were installed a few months ago. I don't know if the low tire press light was on before that...
The RR tire press was high - bled down to specs. Did not fix it.
Stock wheels and tires.
My code reader (which reads my P5 just fine) can't link to see if the computer can tell which sensor...
So - my question - will a ECU reset fix it (doubt it)? Has any one else put new/stock tires on and started getting the code?
Can Autozone read the codes for the tire press system?
Thanks!
I used to sell wheels and tires. Got out just as tmps was coming out. If I remember correctly they have to have a scanner that is just for tpms it is a wireless reader that they put next to the tire and it "resets" it. Visit the people who put on the tires. It could be a faulty sensor. I think they run in the $100 dollar range. Try a firestone or goodyear joint. ps autozone will do you no good in this situation.
