Greetings:
Kinda new to the board
Situation: Got a leaking oil filler cap. Oil leaks out a little bit. Gasket is fine, oil level fine-just drop by drop leaks out. I think this is bruning off the hot engine block as I smell bur oil from time to time.
Recent events: Had a horrible idle/stalling situation. Took out and cleaned the EGR and IAC valves. Runs perfect right now--idles at 500-600 no suttering quite as a mouse and smooth. The leak was occuring a bit before the idle issues now I think it might be a little worse.
Any ideas? thanks
Any ideas? thanks
