leaking liquid again. no smell or color
03 MSP OJ
After i drove 35km highway average 100~125 km|h it stars dripping clear liquid at parking lot. Immediately checked the turbo. It wasnt the banjo bolt . Replaced the Washer like last time too. Its dry at that area. . Gonna inspect radiator and look where exactly its dripping after it cooles down in the afternoon.
If its the fuel line i should smell the gasolne right?
False alarm.... it looks like the ac evaporator or whatever is pouring water out. Should be normal right?
its actually the first time i saw so much water from AC
is it producing more water when u have the remove moisture on ?
it was cold in the past few nights , so i always have removing moisture on to avoid mist on windshield
Is 'remove moisture' the windshield defroster? All cars run the AC compressor do dry the air for the defroster.
not the rear windshield defroster, on the AC control panel, right control left bottom or left mid is the ”removing moisture from the cabin“ option isnt it?
i am pretty new to cars oO thats what i was told whenever i see fogs / waterbubbles on the inner windshield i turn it on
Are you talking about the button to choose between outside air or recirculating cabin air? Maybe one of the vent options like windshield or something?
no, the turning knob thingy for which exit the air is blowing out it has a option " to blow the windshield "
i thought that option also make the AC suck in moisturized air and blow out drier air (which end up pouring water out from engine bay)
It pretty much just removes the fog cause it blows straight on the windshield : )
The ac has a drier which is constantly in use. When's its really hot and you use the ac for a while you can see a lot of condensation which will drip down. Nothing to worry about.
