Knock Sensor records at 4000 rpm, in drive
2005 Mazda SP23
Hi,
2005 Mazda SP23
Has anyone used Mazda OBD Software and tested the knock sensor in drive at higher rpms?
I have a situation that my Knock sensor trips at 4000 and the timing, of course, retards to adjust. I have checked, spark plugs coils, motor mounts, loose objects banging against block, PCM s/w current, carbon build up is clear...Mazda dealer says they can't find anything. I use 89 octane. The airbox resonator is taken off but no other mods to the engine.
Appreciate the help.
