I haven't seen anything recently about this, and certainly nothing that included new part numbers. Just thought I'd put all of these together in one place and make it so people didn't have to wade through multiple threads/pages just to find the parts that work. Plus these prices are way cheaper than all the previous threads have said.
Enjoy.
Listed below are the keys/remotes (standard or flip style) that we know can be programmed to the Mz3. For key purchases, if you provide your VIN to Jason he'll cut your key to your car before shipping. There are premade kits on onlinemazdaparts that combine the appropriate keys/remotes for your convenience. All prices include shipping.
Standard key/remote (non flip style):
-Mz3 transponder key ('04-'07): Part number F1Y1762GX. MSRP-$23.65, Website-$18.92
-Mz3 remote fob ('04-'06): Part number BN8P675RY. MSRP-$76.29, Website-$61.03
-Mz3 remote fob ('07): Part number BAN6675RY. MSRP-$141.05, Website-$117.84
Flip key; key portion: You need both a key portion, and a remote portion (see below for remotes)
-flip key blank with transponder chip: Part number G2YA762GXA MSRP-$47.45, Website-$37.96
Flip key; remote fob:
-Mz6 flip remote fob ('06): Part number GP7A675RY MSPR-$46.35, Website-$37.08 works with '04-'06 models
-MX-5 flip remote fob ('05): Part number NE01675RYA MSRP-$186.20, Website-$148.96works with '04-'06 models
[/list]
Note: All 2007+ US Mz3 models (MS3 included) have a different KEU than that in earlier models. Currently there are NO flip key remotes that can be programmed with the US 2007 Mz3 computer. Canadian owners should still be able to buy the Canadian Mz3 flip key.
Note: In order to program an extra key into your system yourself you need to have at least two working keys. If you only have one of either then you need to go to the dealer to have them programmed in. There is no minimum number or working remotes to program in extra. You can have up to eight keys and three remotes
Key Programming Instructions
1. Insert one of the pre-programmed transponder keys and turn the ignition to "on", leave on for at least one second ( wait until the red key symbol in the instrument cluster extinguishes), remove the key from the ignition.
2. Within 5 seconds insert the second pre-programmed key and turn the ignition to "on" for at least one second but no more than 5 seconds (use the key symbol for this as well) then remove the second key.
3. within 10 seconds insert the new key in the ignition and turn the ignition to "on", if you are successful the red key symbol will illuminate then extinguish after about a second.
If you are not successful the red key symbol will flash repeatedly to indicate that you have inserted an invalid key. Remove the key, wait a minute and try it again, it took me a few times to get it perfect and I had done it before.
Remote Programming Instructions
Step 1: Open driver side door and leave open.
Step 2: Lock and Unlock the drivers door using the power door lock switch on the door
Step 3: Insert key into the ignition.
Step 4: Turn Key to ON position and return to Lock (off) position. Do this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off) position.
Step 5: Close and open the drivers door 3 times. Leave door open after this step
Step 6: ECU should respond by locking and unlocking the doors once.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series (about 4) of door locks and unlocks. You're done!
Enjoy.
[/list]
Programming Guides for keys/remotes:
(courtesty of TGM3)
