Just bought!!!
supergoose
07' Mazdaspeed 3 Sport
Just bought the SU TMIC 3.25". Can't wait to get it. Also on the way, a new turbo inlet pipe.(lol2)
Make sure to take close up pictures of the mount before and after the install please!! Did you get it in any special finish?
nice supergoose. please give more pics then the rest, and please let us know. no one i have talked to had anything bad so it should be golden.:)
I wonder if a fuel pump upgrade is in order once you go TMIC with an intake/bpv/exhaust.
no, only time you would need fp is if you go higher psi, or ur getting cut or something with the dp....just a cb with intake,tmic and bpv is fine without a pump
Yes, I got it yesterday!!! Pics will have to wait because I lost my USB cable for my camera and have 2 get a new one. Went 4 a test run and it blew off the inlet hose to the TMIC??? They r the stock hoses and am going to get the SU hoses 2day. All clamps were tight but I did notice the bend in the inlet hose was bent, not rounded. That was probably the reason 4 the blow off of the hose.
I ordered a used ETS from a member of this forum. I definitely don't want anything blowing off my hose if you know what I mean.
Probably is the best thing to get boost tubes with any aftermarket TMIC. Other than the tube coming off, was the fit good?
Waiting for pics!!
