It's Wide Path Wednesday!
A JBR Wide Path Intake will help you increase performance and can add a touch of color to your build if you wish. All intakes listed below are in stock and ready to ship so don't wait, order yours today!
Shop Tru-3.0 Wide Path Full Aluminum Intake System
Shop Tru-3.5 Wide Path Full Aluminum Intake System
Our 3" and 3.5" Wide Path Aluminum Intake Kits feature the ability to change the turbo side coupler to accommodate every size turbo inlet ranging from the stock turbo all the way up to a 4” inlet. No matter what stage you are in with your build, JBR has the intake to fit your needs. Now all you need to do is pick a color!
Shop Tru-3.0 Wide Path Full Silicone Intake System
Shop Tru-3.5 Wide Path Full Silicone Intake System
JBR's Silicone Wide Path Full Intake Systems extend from the MAF housing all the way to the transition at the turbo. The thick, 5-ply, wire-reinforced, high-temperature silicone construction is far superior at insulating the intake air from extreme engine temperatures. This translates into lower boost air temperatures and more horsepower that no other aluminum intake can accomplish.
Shop our website today!
www.JamesBaroneRacing.com
