ISO 99-01 Protege tail light thread distance at attachment points
TeamFRD
Soooo.... I spun into a snow bank and smashed in the RR corner about 4 inches, destroying the tail light and twisting the trunk lid. Truck wont open.
I want to install a replacement tail light lens but since the body (metal) is pushed in and I cant get into the other side to measure for myself.
If the distance between the threads is close to OEM, I can get a replacement and use just 2 nuts, closest to the truck lid to hold it on for the time being. All bulb wiring is attached and dangling there.
If you have access to a right rear tail light lens, please measure the distance between the threads, where the nuts attach from the inside, for me.
[I only want to crawl thru the back seats once to fix this. ;-) ]
