I've been driving a company car a lot for the past year. Now, I no longer have it and am driving my P5 a lot more than I used to. I've noticed that it's doing some strange things that I don't recall happening before.
First, when I start it when it's already warm, it starts right up, but then the RPMs fall to 450-500 RPM and it shakes for a second or two and then bounces back to about 750 (where it's supposed to be). I've hit the gas more than once when it does this because I think it's going to stall. It hasn't yet, but I'm not sure if it wouldn't have if I hadn't helped it along.
Second, when the A/C is on in Park and it cycles off, it does the same thing (drops from about 800 RPM to about 500, bounces back to 800, then levels off at 750). When the compressor kicks back on it bumps up to 800 again, then repeats itself.
I've also noticed when idling that there is a slight whistling sort of noise which I assumed to be air moving through the rather complicated looking factory airbox. I suppose that it could also be an intake or vacuum leak of some kind that might be causing these issues? It runs perfectly fine otherwise.
Do everyone's cars do these things, or is there something wrong and what might it be?
