Is there an antenna input on the back of the 09/10 CX9 Bose head units? HELP!!
sbmrinaldi
07 CX9 Grand Touring FWD
out my 07 head unit for a 2010 Bose head unit and there is not an input on the back of the Bose 2010 unit for the antenna unless they changed the cable from a plug to a pin style connection. If that is the case how do I get the antenna hooked up? The new system was a plug in play with the exception of no antenna input. Need help car is torn apart.
Found out the newer model CX9's have a connector type and not the old style pin connection. I found out the Honda adapter fits the Mazda radio perfectly, so problem fixed with a $20 Honda adapter found at Best Buy.
