Is there a howto for cleaning the MS CAI?
its a pretty strait forward mod! really easy! take off the stock air box and replace with the cai!
I've already got the cai on, I had the dealer put it on.
But it's time to clean it and i can't find the filter or figure out where to jack it up.
So why didn't you put it on....Worried about your warranty?
Easiest way to get to the filter is from the bottom. Buy some ramps (any auto store/wallmart etc), slide under and undo the splash shield. After you loosen the hose clamp, it should pop right off. I believe you can also access it by taking off the driver's side wheel and undoing the wheel liner but that might be more of a pain.
You should have gotten a cleaning kit (2 white bottles) with the CAI. If not, I believe the AEM dry flow cleaning kit could work (someone correct me on that).
^I'd do it every 10-12k. Some people say 20k but it's probably a good idea to examine it after around 10k or so to see how it's doing. When I removed mine, it was pretty dirty and I had it on for around 15k miles.
