- MP5T / 944
CustomMSP said:Looks good. Are your pipes 2.5" all around? You have the same turbo as the MSP. Based on my rough calculations the inlet on the turbo is 2.25" correct? And the TB is 2.5"?
Thanks again.
The port on my T-25 is 2" and the Throttle body on the P5 is 2.5"
You might notice that the IC has 2" on 1 side and 2.5" on the other side. It was purchased with this in mind so I did not need to step up to the IC. The intake before the IC is all 2" Aluminum and 2.5 after past the IC. The plumbing scheme was really ****** up. I attacked the task of installing the IC then worried about the plumbing. Custom means "More work" in Latin, I am sure of it...
It's a hard place to see but the MAS is on the pressure side before the two extra fuel injectors...(Red). The BOV is a Turbo X/S RFL. It's right next to the T-25 on the 2". This was done so the car does not stall every time the BOV opens. Ask if you need a better explanation..
Later...Brian
