Installing OEM power driver's seat in the CX5?
Strangehate
Mazda CX5 Vision
Hello.
I currently own a European spec CX5 with manually adjustable cloth seats. I have found a good deal on a set of original CX5 leather seats, but the only problem is that the driver's side seat in that set is powered while my current set is manual.
When looking under the seat there are a lot of wires and harnesses. Are these only for the airbag and heating, or is it prepared for powered seats?
Thanks in advance.
Edit: Maybe it should be stated that the CX5 is from November of 2013, and the automatic seat is the 8 way adjustable model.
I bet all the wiring is there. It costs less to make them all the same. The electrical manual is on line so you can check.
Btw when switching seats, do not turn on the ignition until the air bag harness in the new seat is all set. This will save you getting errors.
