Ok guys (and gals) I am going to be installing my tsudo header and sls midpipe this weekend. I just had a few questions going into it.
When removing the o2 sensor, did you use an o2 socket or did u just use an open wrench to get it off?
How were the spring loaded bolts when you took them off? Did they break off or were they seized at all? This is prolly my biggest worry right now outside of throwing a cel. (i am going to try the non-fouler trick)
Anything else i should be prepared for? Any advice would be much appreciated! The reason I am asking for any help is because when I was putting on my rb cat back the simple install turned into a 5+ hour hell that still haunts my dreams, so I just want to be prepared this time. I will put up a video at some point too.
