Hi everyone..
First post, so hopefully this is the right section! I did a search for my DTC codes but nothing came up....
2019 2.2D [184] GT Sport Nav+ AWD in a very nice Machine Grey - based in Bedfordshire, UK.
So, a few days ago, my Check Engine light came on, and a report from an ODB-II scanner revealed a code P24C6 which I tracked down to do with the particulate filter. I ran a bottle of CataClean through the system, as per the instructions, but the MIL light remains on.
A further check of the ODB-II codes now reveals the P24C6 has gone, but I now have a P1640 code, but this is being reported across a number of different ECU Modules. The message reads:
Powertrain DTCs Available in Another Module
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
The same message shows in
Engine Control Unit (4 times)
Transmission Control Unit
Dashboard
Access System
Adaptive headlights
SRS/Airbag
Driver Seat
I have managed to find out that P1640 breaks down to P = Powertrain, 1 = Manufacturing code, 6 = Computer Output, 40 = error code. But I can't find any info on the error code itself, or what the test is it refers to. I suspect this is something I am going to need a Mazda dealer to plug in the M-MDS computer, but I thought I would exhaust all possible research options before I do!!
Has anyone come across this code before?
I have come across some possible info around drive cycles, but can't find what a drive cycle for my specific vehicle, so I suppose it is possible that the condition will clear once a drive cycle has completed.. ?
Thanks everyone!
Darren
Dashboard
Access System
Adaptive headlights
SRS/Airbag
Driver Seat
Thanks everyone!
Darren
