2017~2025 I would like to know how to remove front bumper cover for 2017
I'm finding how to remove the Front Bumper Cover of 2017 for installation DRL by myself. Any share a link?
Probably not much different than previous generation, unplug all light connectors, remove the plastic pins in the wheel well connected to the front bumper, remove the bolts/pins on the under tray that connect to the front bumper and the pins/screws (possibly rivet) on the plastic cover at the most forward part of the engine bay over the grille
https://www.mazdas247.com/forum/sho...-Proper-use-of-the-quot-How-To-quot-Sub-Forum
Probably not much different than previous generation, unplug all light connectors, remove the plastic pins in the wheel well connected to the front bumper, remove the bolts/pins on the under tray that connect to the front bumper and the pins/screws (possibly rivet) on the plastic cover at the most forward part of the engine bay over the grille. A bolt might be shared among the headlight and bper as well. Pretty visual procedure (look for attached bolts)
