jdub260 said:1) CP-E Turbo Back System (When they get it ready)
2) ECU Upgrade
3) Eibach SportLine Springs (and some Camber Plates)(maybe new shocks and struts)(and new brake pads probably hawk)
4) Wheels and Tires
A BOV may land in there somewhere but right now I don't think so.
Money is the limiting factor....as always.
Whats your 1/4 mile time with 20psi? and can you tell a real differance in performance? Dynoed?p5freek said:ok cool . u can start off by putting a boost controler, im at 20 psi and i even added a fuel cut defender and it works great . i put the sportline eibach they are very good. the ECU upgrade i will wait till they come out with something good. and the downpipe i cant stop waiting . i want it (ughdance)
buit9110 said:where did you get the fuel cut defender?
jcgemt2003 said:Whats your 1/4 mile time with 20psi? and can you tell a real differance in performance? Dynoed?
2) ECU Upgrade
4) Wheels and Tires
Wiggum said:You are starting in the COMPLETE wrong place...
1. Eibach springs are crapp, they are designed for the regular 6 and your car is actually going to handle worse... remember the MS6 is 500 pounds heavier than the Mazda 6i which they were intended for....
2. There are no camber plates for the MS6 and there never will be, this is not that type of suspension.... rear camber is already adjustable, and front can only be adjusted with some custom adjustable a-arms (there should be some of these made soon...
For the ECU upgrade, yes it will definately help, can't disagree with you there, I have heard UniChip has a Speed6 ready for tuning...
Adding a Boost controller giving 19-20 PSI to redline has been done, I can't deny that, but if you look at the flow charts of the exact turbo from Borg Warner you are taking the turbo completely out of its efficiency and in some cases make actually be LOSING power...
My ideas for you
1. The CP-E turboback is a great idea, I can't wait to get a catless one, but once again we need some tuning...
2. The only springs designed for the Speed6 that are actually decent are the AutoEXE springs, member Fedinand has them...
3. Wheels and tires help any car, I have 18x8 RX8 wheels on mine with 235/40/18 Falken Azenis and the car drives very well...
Not sure if you have an intake yet but that is definately the first place to start, second only to a good boost gauge... an essential in any forced induction application...
p5freek said:ok my friend , let me tell you. i have the eibach suspension and the handling is amazing and YES they are for the mazdaspeed 6. my car is dropped 2 inch. i have my car with a turbosmart boost controller at 17-18 psi daily drive till 7000rpm and let me tell you that the turbo is pushing till the end . u dont feel no power loss like in the stock boost that falls at 5500rpm.
u are right about the camber kits and stuff , but to start off for a good budget , a cold air intake , manual boost controller , exhaust cutout (if you wanna keep your ride quite on the street and loud at the track)
BlueSolrac said:Wiggum is right. It has already been discussed. Check out Mazda6club for more info.
p5freek said:im not saying that you are wrong but i have them on my car and they are great the springs. and if the shock dies then warranty here i come!! when u are friends with the owner of a mazda dealership u can do and try alot of stuff on the car. i will go and dyno my car for what u are saying about the turbo. its been 7 years that i drive turbo modified cars.
rx-7 twin turbo 93 . protege 5 turbo(gt28rs) / nitro , and now mazdaspeed 6
i believe what you say is good for the safety because when they made that car the new that more mature people will buy it like in the 40's plus so imagine the boost pushing all the way till 7000k !!! u guys have to think about the confort of the car . it cannot be brutal stock , they have to make some sort of smoothness. u guys should try it!! a boost controller is not even a 100$ and install is another 100$ at the most. u will believe me then!!
i will even tell u how to install it
The turbo is good for 30 PSI if you want... that doesn't mean its being efficient...p5freek said:OK man . im lying !!!! (first)
why dont you try it and then come back and talk to me. u show me numbers , i show u a real fact that it is working.. the turbo is not maxed out. why dont you call mazda USA and ask them the turbo is good till what psi??
i did and they said 25psi!! (RTM) so please !! it is not an expensive mod try it
