I broke some stuff, and ended up with a new mod
Shorebroke
M-Spec's Young Gun
02 LX
I was trying to put on my shift knob that i've had for a while now. And from the get go i knew i was gonna **** up. First thing, i tried to see if i could take off the stock shift knob thingy, with the overdrive button still inside. Sadly, i didn't, and i snapped the little triangular plastic piece that pretty much allows my car to shift. So i tried to superglue it back on, and it stayed for a while, but whenever i tried to shift, it wouldn't go, even with the car on, and my foot on the breaks. Soooo, some more fiddling we did. Than, when we took out the plastic piece, which was superglued and taped, the spring inside popped out, and hit me in my forehead. i was like "WTF!?!?!", than after that, a little lever thingy at the bottom of the shaft fell off. I honestly don't know what it does, but i seen it before it fell off, and i was like, "This cannot be good at all"
Now, i was in the parking lot at Safeway with my friend while doing this, so i had to fix it somewhat, just to get home at least. So we fiddled around somemore, and we were able to get it to work right, sorta. We ended up not using the white plastic piece, the spring inside the shaft, or that little lever at the bottom of it. The result, a REALLY short shifter, that shifts to any position without having to press my foot on the break, or needing the car to be on in order to shift. I actually like the look of it, since the shift knob rides really low, but....i'm scared it might get stuck or something later on, so i gotta get it fixed, probably at mazda, since i don't think anyone else could fix it, and that will cost some money, which i need for the paint job. So yeah, as long as my car can shift, i'm keeping it until i can get it fixed, but check out the pics i took afterwards. I actually like the look of it to be honest. All i need is a Shaundarbie boot now, and i'm good to go.
whoa... that may be a little dangerous... shifting without needing the brake. u may shift from drive to reverse when driving one day.
if u want, i can always take a look at it to see what can be fixed?
peace
Yeah, if you can, that'll be helpful. Luckily, to shift, you have to give it a little muscle, so if i were to tap it, it wouldn't budge. I saved all the pieces that came off, and all i really need is a new plastic piece that goes inside the shaft.
Also, i didn't want to get stuck at safeway because i couldn't shift from park, to drive, so i just needed to get it working for now, and this was the outcome. I wanna get it fixed, for it's scary knowing that it COULD go from drive to reverse on the road.
haha ic.
yah i need to order a new plastic piece too. ill call mazda about that. i need to reinstall my momo shifter too, im getting a lot of problems right now. we can have an install party, yay haha
peace
er u not worried u slam into reverse while driving? trust me, it has happened. i seen a p5 in mazda's repair section and it was covered in dust because mazda cannot fix it. i know and all the mazda tech guys know this kid was racing while shifting gears and missed and wacked it into R on the freeway. what he did was shattered his pistons, shifter, and really messed up his engine. the guy is lucky, mazda said they'll cover it under warranty (so mazda said). i never did know what happened 2 that car. i wonder if they did ever fix it. the prob was they never needed 2 do such an extensive repair so parts were simply not avail 2 the repair. anyways good luck on fixing your shifter.
