The older 3s prior to the body change in 2013 are being seen less and less. Im keeping mine running @ 160K and plan on keeping it.
If anyone has things they've had to replace or repair ,, as well as tips to keep em on the road . Please chime in .
My 2010 has the 2.5 ( GT HB - AUTO) which was only in the 10-11 , but the 2.3s 2.0s and 2.3disi-T were ALL slightly different.
First the drive belt ( water pump , alt and a/c compressor) was replaced at 90K but it was not broken or cracked. Then I needed a new valve cover gasket at about 110k as I would smell oil , but not like burning , more like vaporized oil on steep long hills doing 60+ and realized they leak off the backside due to the heat rise off the exhaust manifold. So problem solved. Of course the Coolant was at 100K , ( now due again ) Did spark plugs at 115K -easy = 20 min job. I had my TCM fail on a start-up in the garage at 120K and the dash lights were - Check-eng, D-Drive and M-Manual ..it ran but needed to manual hard shift the auto trans until I replaced the TCM which is under the battery. This is a common time for this to occur. In a hot environment possibly sooner. I flushed the power steering fluid which was like swamp mud at 120K as the power steering was " groaning " and then it stopped. Like NU . Did the front struts and rear shocks at 125K , then the rear wheel bearings/hubs ( one piece ) on both rear at 130K - the front bearings are quiet - so ok there . I do the trans fluid every 30K , oil every 4-5K , I have the GT so Xenons and LEds all around - no issues except the "nagare" light filament went on the front headlight - changed it - easy - Never left me stranded , Been thru lots of tires , but no unusual wear . I lost power to all my lighter sockets and cant find the issue -- fuses are good , wires are good , I replaced the imputs with new- still no juice -- anyone ?? So other than that it has a timing chain - so Im pretty sure its going 300k - If anyone has other long life service tips --It would be appreciated- Lets keep these on the road ! Drive safe- the parts are getting harder to find and more $$.
