I went on an adventure today. I've been dealing with an idle issue for the longest time. Well I think It's fixed. WOOOOT. heres a little how to on how i did it.
1st grab a beer lol.
disconect the intake pipe
remove the throttle cable and 4 12mm bolts/nuts that hold the tb on. Remove tb assembly
remove vacuum hoses
Remove pcv hose
Disconect the 2 electrical connections going to te vic and fuel pressure solonoids
Remove all these 12mm bolts/nuts. There is also 4 12mm bolts on the bottom half that you have to remove to get the top half off.
also remove this bracket while you're down there getting thos bottom intake manni bolts off. It's right by the starter.
Grab another
remove vacuum hoses
Remove pcv hose
Grab another
