That guy is completely wrong about the hatch operation and calling it a secret button is kinda dumb as it*s clearly described in the manual. Just because some clueless salesman calls it secret doesn*t mean it is.
So to clear this up. If the entire car is locked already, and you walk up only to the trunk and open it, once you close the trunk it is locked again. You don*t have to press anything to re-lock it. Don*t believe me? Lock your car, open the hatch, close it, walk away and put the key down on the ground 5 feet away, walk back and press the hatch open button again and it won*t work. If you have the key on you the proximity sensor will keep letting you opening the hatch over and over but there*s no need to re-lock the car.
Additionally the lock button on the rear hatch to the right is for if you don*t have walk away lock enabled. It*s so you can get out of your driver door and remove cargo from the trunk and then lock the whole car without having to walk around to either the driver or the passenger door to lock the vehicle.
