So last year, car would studder a bit at times while sitting on the light or upon acceleration. Worst thing is that it's random. Happened once every month or so.
Fast forward to this year, cold temps kicked in and now it's escalating.
Few months back car would get a check engine light blinking and had no power. Upon pulling over/scan the codes, I got the following:
P0421 warm up catalyst below threshold bank 1
P0300 random/multiple cylinder misfire detected
P0660 intake manifold tunning control ckt open bank 1
Clear the codes, car is fine.
week or 2 go by, same thing. I used to be able to shut off the car, restart it and CEL would just be on (not blinking). That has now ended as of this week. I need to clear the code in order to stop the blinking.
Clearly, it's getting bad....and I know....I've been negligent.
So I've been doing some reserach and the whole P0421 code sounds SCARY.
I just checked to make sure the spark plugs are not lose. I did notice that Cylinder 3 bottom of the coil boot was broke, but it still clips in just fine (the rubber thing on the bottom of it was broke).
Worst thing about all this is right now car is fine. No cel, runs great......
I was thinking about with either startign off by unscrewing the bottom O2 Sensor and plugging it (letting it hang) or get one of these?Auto Dynasty - Universal O2 Sensor Spacer Adapter Isolator Extender
https://www.amazon.com/dp/ (commissions earned)
