HELP: Installing Alarm/Remote Starter
This one thing I'm not sure about is how to wire the central door lock
system. I know that our cars run a negative single wire to lock and unlock
the doors....
I know you need 2 relays to make the alarm lock and unlock
Heres how I got it hooked up....please correct me if I'm wrong....
1st Relay & 2nd Relay
87 - Ground
86 - 12v Constant +
1st Relay
85 - Lock pulse from the alarm
30 - Lock wire to the - single wire (lt green/red)
2nd Relay
85 - Unlock pulse from the alarm
30 - Unlock wire to the - single wire (lt. green/red) w/ 1.5 K ohm Resistor
I need to know if this set up is correct....I haven't tried it out yet
coz I dont have em all connected....I will try them tomorrow...
If anybody has a different set-up with their alarm install, please speak-up
Thanks
the doors....
87 - Ground
86 - 12v Constant +
1st Relay
2nd Relay
Thanks
I fixed the diagram of exactly this in the alarm remote starter thread, check it out.
http://www.msprotege.com/forum/showthread.php?p=94504#post94504
The only mistake is that its the lock wire that needs the resistor, not the unlock.
You'll notice the diagram has +12 volts on terminal 85 not 86. It doesn't actualy matter. Terminals 85 and 86 are interchangable on 99% of SPDT relays.
Thanks! I got it to work...
I got a another question that maybe you can answer....
The alarm I have installed is not actually an alarm...its a
keyless remote and remote starter....
All this time, I thought it was an alarm system also....
The brand is 1WFM 4button Compustar (not the pager)
Do you know if theres a Car Alarm add-ons out there ?
If so, can you name some?
I know that it can be done because this alarm has a
- rearm/disarm output wire which I'm sure that goes to
the add-on alarm....
I can't hlep you much their. I haven't delt with compustar much. DEI usualy works it the other way where the remote starter is addable. I'd call compustar.
