Won't work, the crank is 2mm larger on the MS6 vs the NA cranks.JuanHu said:ok,today I found EAGLE rods for the Wiesco pistons,the part# is CRS6094F3D
u r a real nice man!mu..haha4DRHTRD said:Here's all the hard parts I could find for the NA car, I hoped that they would work for ours but I'm still doing research:
Enjoy - BTW, any Duratec parts for the 2.3L work for the MZR 2.3L NA cars as they are the same motor internally. The stock crank breaks at 400 crank horsepower so you'll need a forged one. The popular upgrade might be fitting the MS6 crank 51mm vs 49mm into an NA block (I have no idea if this will work).
http://www.marcymotorsport.com/MM-html/FORD/focus/focus_engines.htm
http://focus-power.com/view.php?showme=Stroker_Short_Block_Duratec#
seems to be a common issue...a lot of arrogant speed 6 owners around here.evilmonkeyMSP said:its the 6/MS6 forum... its for both
wannabe said:seems to be a common issue...a lot of arrogant speed 6 owners around here.
(not me....)
