Need a little help here. About a week ago I went to start my car and nothing. Checked relays and fuses, all good. Pushed the front clutch switch by hand a few times and it fired right up. Well today the same thing happened only this time I couldn't get it started. So my car's sitting at job site 40 miles away. Is there anyway to bypass the switches without losing my cruise control? I also tested the switch with a volt meter and got .02ohm when closed (as it would be with the clutch depressed) and nothing when open. Is this what it should be reading? Thanks for the help
