DuramaxLBZ
- 2004 mazda 3
Hi, I have a 2004 Mazda 3..it has pretty heavy vibration when you turn the wheel to left when driving...it is real bad at 45mph or faster. The whole car makes a "buzzing" noise. It vibrates when you are on the brakes, or not, when turning the wheel to the left...its totally quiet when turning to the right. It seems to make the noise more on the drivers side, but its hard to tell since the whole car seems to "buzz". I have replaced many things so far trying to figure it out. Here is a list of things that I have replaced...New tires, balanced all the tires...Had an alignment, new drivers side front wheel bearing(old one wasnt bad), new drivers and passenger CV shafts, just replaced the passenger side motor mount which was bad...new brakes, rotors on the whole car, checked rear wheel bearings (no play in them at all). I am looking for any kind of advice or if anyone has had a similar problem and what the solution was. Thanks
