A/C worked fine but in winter the heat only works in passenger side , checked all 3 flap actuators all seems to operate , tried using dual mode and turning up heat to max on driver little difference , turn temperature to 15 degrees a/c is fine , cant see if there is a an actuator/flap that controls passenger or driver side . its same for driver side windscreen heater footwell and centre vent. anyone have ideas as to what may cause this?
I can see there are 3 actuators , presumably one is for recycle/external two is left side and one for right side.
