Have camber plates, BUT got Cobb Springs... should i install or sell?
So I picked up some camber plates over the winter as i had prokits that i was going to install, but being a good fanboy lol i sold them and got the cobb springs since they are actually made for the ms3 not just fit it.
Cobb says you don't technically need them, but my question is since i have them should i install anyways OR since the Cobb drop is less would I actually get positive camber \ / which is even worse then negative handling wise
install or sell?
Personally I would get an alignment without them and see if you get the results you want. If you don't need them don't use them.
get an alignment first to double check I guess, but everyone I have seen who has them hasn't needed the camber plates (including me). Tire wear is even too
