Got the racing mazda header need help
i need the diagram for the 02 sensor trick, i searched for at least an hour and couldn't find what i was looking for
no, thats not it, thanks anyway. i don't necessarily need the diagram. if someone could just tell me how to hook up the o2 wires then i would be set
dude, why ask for help if you are not going to use it? that link has what you want to know in it. the top o2 sensor goes into the header. the second o2 sensor will need to be 'fooled' into thinking it works fine, when in reality, it isn't even hooked up. if that is what you want, i suggest going back and reading that link that was posted to find out what is needed to be done.
if you are really hard bent on doing it yourself, this is what needs to be done:
http://www.jdmfan.com/technical/performance/o2sensor_simulator/
i would use it if it were the thing i was looking for. the link didn't have the information i was looking for. the link you gave me on how to do it myself is not the right info. the hookup is for some other car. i don't appreciate having someone jump on my back when its not warranted. the thing i am looking for is a little diagram with both the o2 sensor wires represented and how to switch them around. thats all
MacProtege5,
What exactly are u looking for? I understand u are looking for a diagram but of what? What is it that u are trying to do??
Sorry for all the questions just seems like sum-one could help u more if u specified more.
Peace,
Zane
the diagram i am looking for is of the wires for both of the o2 sensors and how to hook them up, i know you just put the first sensor in the header, then there is something you do with the second sensors wires. maybe you put a resistor or something somewhere? please help
I think you are simply not giving us enough information. The link njarmemka gave you is just fine for building the O2 sensor trick thing (which is what you asked for!!!), this is what you do with the second sensor. You add this thing to it so it fools the ECU into thinking the readings are right. It will work for any OBD-II car (which your car IS). If you are wondering how to hook this all up to the ECU (which will be different for all cars, but VERY close), than this is what you should be asking for - a diagram of the P5 ECU.
Chris
nah, i am looking for a diagram that shows both of the o2 sensors wires and where to put the resistor, like in between what wires. its a very simple diagram that i saw on this site before
