gas oil coming from breather tube?
blkspeed
title says it pretty much i noticed a brown stain and clear condensation in my cai it smells like a gas oil mix? mite be wrong? but its coming from the breather tube? i have no idea what the problem could be or if its normal? i wouldnt think so and my issues are running rich at idle and a 500rpm idle speed. i noticed this before i changed the sparks and the induction cleaning and i just cleaned the MAF which was super dirty on one side and when i put it back it stayed at 700-600? i was fine with that but then the 500rmp and cel came back on wtf... desided to clean the MAF again and reset the comp. but i know its not the fix on the brown stain/gas oil smell/condensation
do u have a catch can in line from ur pcv to ur intake manifold? sounds like ur pcv line or the actual valve isnt releasing crank case pressure so its pushing through to the breather attached to ur intake.
