Saskatchewan17
- 2008 TR Mazdaspeed 3
For Sale!
Is an ATP Greddy Type R/S/RS Blow off valve adapter specific for the Mazdaspeed 3/6 and Mazda CX-7. This can be used with any of Greddy's blow off valves (the Type-S, Type-RS, and Type-R). Comes with the 5mm Allen key bolts shown in the pics. This piece has a little bit of scoring on it from normal use and taking the valve on and off of the cold pipe, but it works fantastically and really isn't a "wear item." Plus, you can't see any scoring at all when the valve is on the car.
SOLD!
Next is an authentic GReddy Type-S Blow Off Valve that is a little damaged. The internals of the valve are fine (I know because I just opened it up last week and cleaned it off real nice and made sure everything was tightened down properley and in good, working order). With that said there is a bad problem with the valve. The purple "top hat" and adjustment screw place in the valve is stripped and no bolt will fit in there. The valve was sold to me like this with the "stock" screw and nut stripped, so I tapped it out a couple sizes bigger and was using it like that for a while with no problems. Then, stupid me adjusted the valve wrong and stripped the threads in the adjustment screw place again. So my friend said he would have a look at it, and he tried tapping it bigger, but it didn't work... Basically all this valve needs to work is a new "top hat" or adjustment top. It's a good weekend project and I'm selling it way below what the normal list is for these valves. It makes a sweet sound once installed and comes with a gasket to fit it to an adapter or directly to the cold pipe depending on what adapter you have.
Price: $50 + Shipping
Basically if no one buys the Type-S it will become a cool, expensive paperweight.
Anyways... on to the pics:
See? Nice and clean:
Yeah, it's authentic:
SOLD!
