My engine on my 2003 protege 5 is shot. I'm looking at a FS-ZE to swap in but the problem is it does not come with a wiring harness. I've looked through this forum and cant find a definitive answer to if I can use my stock FS-DE harness on the FS-ZE. I've read that I can swap over the ECT and knock sensor from the FS-DE and it should run fine however I do not know if this is if I use the FS-DE harness or the FS-ZE harness. As many others have shared it is near impossible to find an FS-ZE harness so if there's a way to make the FS-DE harness work that would be ideal. ANY ANSWERS WILL HELP. THANK YALL IN ADVANCE.
