FS: 2002 626 intake manifold WITH EGR pipe
Status
Not open for further replies.
Here's a 626 intake manifold off a 2002 motor... it comes with everything you see in the pics... fuel rail (for perfect fitment, no need to use your stock fuel rail and have it flopping around), EGR pipe (fits perfectly to the stock exhaust manifold), vacuum hoses, 34psi (at idle) fuel pressure regulator, 208cc 626 fuel injectors, PCV valve with hose, EGR valve mounting bolts, solenoid brackets, vacuum reserve tank (for VTCS), VTCS valve assembly, and throttle cable bracket
what's missing:
some of the fuel rail mounting spacers and bolts
throttle body
EGR valve
vacuum solenoids
the intake manifold support bracket is the SAME as the protege one and is not necessary... I do not have it or it's yours "free"
you all should know what this intake manifold does, so no need to explain
this came off a motor with around 65k miles on it and I took it off the motor myself (motor was bought complete for somebody else)
asking $225 *shipped* to the US only by UPS
paypal only
PM me for paypal info
please update your signage with the correct info (your userID, today's date, and mazdas247.com) and retake the photos
PM me or any of the section mods to unlock this when you're ready
Status
