ok the service manual says that the front strut mounting block can be rotated to change the camber and castor. The non stock locations changes camber or castor or both by a number of +30 deg. Just to verify if changing the location it will add positive camber not negative, correct? sorry if its seems obvious but I know for a fact my 7 mounting block increaces negative camber, and i just want to make sure its not making negative camber.
