In order to try to improve the shifting, do you recommend buying BOTH the Kartboy shifter bushings AND the front engine mount at the same time?
Or should I try the bushings first, evaluating the improvement, and then later ordering the front engine mount (if necessary) later on.
Any other suggestions???
Thanks
Thanks
