Ty07allstar
- 03 Protege ES
I got my front sway bar installed and used the Ford Escape end links from autozone. Before I switched out the bar and end links my front end squeaked real bad. I was hoping that the new end links would do the trick. The only thing that they did was make the squeak a higher pitch. What would you guys recommend I do to get rid of the squeak? I was thinking about loosening the nuts and putting lithium grease all over the bolt and nut then tightening them up. The end links also had grease fittings on them and I had the shop load them up with grease.
